Funky Firebird Headlights
Old Jun 23, 2001 | 01:41 AM
CheezX's Avatar
I have this problem with the headlight doors. Sometimes when they won't come up until I drive for a while. My car has daytime running lights so that should make them come up when it's dark and the switch also doesn't do anything. I can see that the headlights are on but they point at the ground. If they don't work right away they will after about a minute of driving and they stay working.
I read in the manual there are some self-resetting circuit breakers for the headlight doors. Could these have something to do with the problem? It sucks driving in stealth mode at night.
'90 Red Formula Firebird
305 TPI 5-speed UBC Sports Car Club
Old Jun 23, 2001 | 01:44 AM
Duffster@Work's Avatar
your motors are about shot...
chances are the gears are getting stripped out and when you drive around, the wind gets under them and helps lift them until the motor catchs and then finishes the job.
just my thoughts...
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Jun 23, 2001 | 02:23 AM
CheezX's Avatar
Another thing I remembered...
One time my friend went up to my car and pressed the headlight switch and only one light came up and it wouldn't go back down. I thought "screw this", and manually put it back, then both didn't work. I came back a few hours later and they worked again. Nobody touched the car during that time.
I have a set of junkyard motors I could try. Do they take long to swap in?
Old Jun 30, 2001 | 10:25 PM
CheezX's Avatar
OK, I tested the motors by connecting them directly to the battery and they're fine.
The problem has nothing to do with driving around. If I flip them on and off a few times they eventually stop. Then after awhile they work again. It's like they need time to recharge or something.
The manual says that there are circuit breakers for the headlight doors but I could only find 2 15 amp fuses. Are the breakers built into that black plastic box where the fuses plug in? If the breakers do exist then that could be why it works again after waiting awhile, right?
Old Jul 2, 2001 | 03:52 PM
marald's Avatar
I had the same problem with mine. It was the diode in the isolation relay that was shot...
You could try and replace this diode (the relay was next to the fan in my car) but you'll need a hacksaw to gain acces to the inside of the relay..or you could find a replacement from the junkyard...be sure to get the isolation relay and not the actuator relays as they haven't got the diode in there..
more info on my site:
www.home.zonnet.nl/marald
good luck
marald
Old Apr 20, 2006 | 05:43 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
to resurect a dead thread. . .
don't forget it is possible to replace the firebird motors with fiero motors. . .
sounds like a bad swap, but an option (fiero left=firebird right and firebird left=fiero right)
Right guys?
Duff
Old Apr 6, 2010 | 06:09 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: Funky Firebird Headlights
Right guys?
Duff
bump
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
Cornholio7979
Sep 20, 2018 02:31 AM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:53 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
