Brake lights Help!!
Old Apr 1, 2010 | 02:08 PM
BLOWN25TH's Avatar
Car: 25th Anninversary Z28
Engine: Pro Charged 355
Transmission: Built 700R4
Brake lights Help!!
Guys, i have a 92Z ans when i hit my brakes my dash lights and front running come on. Is this normal?
Old Apr 1, 2010 | 02:14 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: Brake lights Help!!
Sounds like you have a short in your rear lite socket and its back feeding your other lites.
Old Apr 1, 2010 | 04:39 PM
bcmag's Avatar
if you have a single filament bulb in a double filament socket will do this.also look closely at the contacts on bulbls if they melt together same thing.try removing one brake/tail bulb at a time and recheck if symptoms stop.when it does you found the offending party.also poor groud to rear lamps can cause this.
Old Apr 2, 2010 | 06:22 AM
BLOWN25TH's Avatar
Thanks for the help guys. I will get on it this weekend.
Old Apr 6, 2010 | 06:16 AM
Apolo's Avatar
Car: Camaro 1987
Engine: V6 2.8l MPFI
I have the same issue, thats because on the taillights u have the wrong bulbs, probably on the red ones, these bulbs should be ones with two poles on the botom, just check how is it, and change it, im sure that the problem, i have done that and it works.
Old Apr 6, 2010 | 07:34 AM
BLOWN25TH's Avatar
Well i took the tail lights apart this weekend and you guys gussed it i had a single filimnet bulb is the wrong spot. Changed out the bulb and used the correct one and everthing is working properly now. Thanks guys i really appreciate the help.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
