Blower causes engine to quit??
Old Aug 11, 2002 | 09:10 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Here is the deal …every time I turn on my A/C blower my tach jumps and the engine starts to run rough then quits. I have disconnected the air compressor thinking that was the problem but nothing changed. The alternator is new and I tested the charging system and the battery, both are fine. Sometimes I can turn on the blower and every thing is fine until I hit a bump then it goes nuts again. Once again the symptoms… when I turn on my A/C blower the tach jumps, speedometer jumps and service engine light flickers (it is on because of a code 36 that I have not fixed yet) I think I have a loose ground or power wire to the ECM but I do not know where they are. Any suggestions? Also when I turn on my wipers the same thing happens but not as bad.
89 Formula 350
350 TPI
Auto
No mods.
Frozer!!!
Jan 19, 2024 04:55 PM
masonta
Aug 31, 2015 10:14 PM
NinjaNife
Aug 23, 2015 11:49 AM
mhatfield 14
Aug 15, 2015 10:47 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
