atn tim burgess
Old Jul 4, 2001 | 08:48 AM
ausrs's Avatar
atn tim burgess
tim i am doing the swap from tbi to tpi
the tpi is from an 86 vette
harness is from an 88 camaro
car is a 1991 tbi
i will need to
1 make sure speedo works
2 somehow keep vats (is that possible)
3 have all gauges working correctly
in australia it is impossible to get any info on this swap manuals are impossibly expensive
i realise that i will have to re pin some of the ecm /harness wires
can you help at all with any of these questions ???
thanks in advance
steve
email
rsrc@zip.com.au
Old Jul 4, 2001 | 10:06 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Steve, long time no see! How ya been?
The TBI and the Computer you will be using both use an external VSS Buffer, so retain your stock buffer, and wire it to the new computer.
Since VATS wasnt' offered in '88, I don't think it will work with the computer (unless its teh same computer as '89, then you could use an '89 PROM) Or you can just use the VATS as a starter kill.
All the guages use seperate sensors from the ECM exept the speedo, so no problem there. good luck.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
timonator
Sep 17, 2015 06:57 PM
SG91camaro
Sep 5, 2015 10:27 PM
TheExaminer
Aug 19, 2015 10:07 PM
Willie
Jan 18, 2001 06:03 PM
