It happened again
Old Jul 11, 2001 | 04:32 PM
Deimos's Avatar
It happened again
Hey guys i need your help. Some wierd **** is going on with my 88 maro(v6). this is what happened after my other post "something wierd" anywayz, last night when i was coming home form work the same **** happened, my car felt like it was going to die and my rpms rose like crazy. my lights flickerd and ****. what the hell is up? im running only the radio and it does it. I have the factory 85 amp alternator but not the factory battery. I cant stand that. At first i thought it was the alternator(havent got it checked yet) or the battery. If some one ever had this problem or can give me some advice i would appreciate it. thanx.
Old Jul 11, 2001 | 09:25 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
well... lights going off/ car dying - not enough power... the car obviously could run off the battery but for a very limited time. Its possible ur car IS running off the battery and your alternator is sometimes charging or something like that... pull the alternator and have it checked
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
