headlight problems on a 95 ta.
Old Jul 14, 2001 | 10:05 AM
jm91rs's Avatar
On my brothers car, the headlights now go up when the light switch is only turned to make the running lights come on. His foglights no longer work, and now when they go down, they go down and make a noise like a gear grinding for about 15 seconds, what is wrong with this?
Jeremy
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon...non red interior with 4th gen charcoal/grey seats
Old Jul 16, 2001 | 12:55 PM
jm91rs's Avatar
I would guess this is similar to some 3rd gen birds, anyone?
Jeremy
Old Jul 16, 2001 | 01:09 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
You have a couple of things wrong. My 91 had the same problems. !st your headlight switch is shot, and that will fix the problem of the lights popping up with just your parkinglights on. It MAY fix your foglight problem as well. 2nd, one or both of your headlight motors is going bad. When you turn on your lights, they should come up at the same time and speed, the one that doesn't is the one that is suspect. Otherwise have someone turn the lights on with you watching the motors. The tops will spin and you can see which one has the problem. I replaced the moter on mine fo $40
Chris G
91 TA WS6
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
