Need Help with MSD
Old Jul 18, 2001 | 10:11 AM
MidnightZ's Avatar
Need Help with MSD
I am in the process of redoing my ignition system. My computer has been removed and I am going to be running an MSD Pro-billet distributor with the MSD-6AL kit that I purchased from Summit. I found a place where I would like to mount my box, but is there and easy way to mount it to my firewall and still utilize the vibration mounts? How has everyone else mounted their box to the firewall.
83 Z28, 305(LG4), T-tops, T-5 Transmission, Centerforce Dual-Friction Clutch, Hedman Shorty Headers, Hooker Cat-back, Weiand Stealth, Holley 600, MSD 6AL, MSD Pro-Billet Distributor, Computer Delete, EGR Delete
Old Jul 18, 2001 | 11:27 AM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
I would also like to know where to place the 6al box, I have NO where that I could mount it straight. The only place found is if I remove the radiator overflow and mount it there at an angle and only use three bolts. Appreciate any advice on the subject as well. As I need to put it on tonight, but cannot find a place to do it. :-(
James
Old Jul 18, 2001 | 03:34 PM
Jza's Avatar
Jza
How about here:
I didn't have to shorten or lengthen any wires either, and I can easily reach the RPM pills to change.
Old Jul 18, 2001 | 04:57 PM
87tpi420's Avatar
you could use the vibration mounts if you made a little riser bracket out of metal (if available. one person on here mounted it to firewall and got his hand up underneath to tighten but said it was tough. what i did was went to home depot , and in the nut and bolt section....all the little trays of hardware they have small rubber bushing type cushion thing-a-majigs. they look like small grommets (i cant remeber they might even be.. but i used those and mounted with self tapping screws and those rubber things.
hope this helps some
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
