Manual fan switch
Old Jul 18, 2001 | 11:40 AM
DannysZ28's Avatar
Manual fan switch
How easy is it to wire a fan switch in so I can turn on my fan whenever I want?
1985 Camaro Z28
minor mods, wires, filters, etc., Accel SuperCoil/cap/rotor,
305 bored .030 over, new pistons, cam, lifters, timing kit, water pump, high-flow cat (3" out), Dynomax Afterburner muffler (2.5" out), O2 sensor, MAF sensor, 160W JVC head unit, Rockford Fosgate Punch 360 amp, 2 JL10W0 subs, custom box.
"You may laugh in the face of fear, but it'll be a nervous, unconvincing little laugh."
Old Jul 18, 2001 | 11:52 AM
DannysZ28's Avatar
Also, from reading some of the other posts it seems like a lot of cars have dual electric fans whereas I've only got a single. Is this normal? Also, my car is displaying the same symptoms as a few of the others: at speed, it's below 160 degrees, but stop at a light, and watch the needle climb into the red. Is this something as simple as replacing the sensor? If so, where is it located? Thanks guys
1985 Camaro Z28
Old Jul 18, 2001 | 07:59 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
It's easy. I've seen this question so many times I think someone needs to do a tech article on it. I have a single fan too. I just tapped into the power wire going directly into the back of the fan motor. Hook up a switch to 12 volts and wire it to the back of the fan. If I get a chance I can post pictures.
'91 RS 3.1
SSM SFC's
Energy Susp. Hyper-flex kit
GTA Sway bars
Clarion, Phoenix Gold, JL Audio, etc.
Quote "If you can't beat them, arrange to have them beaten."
- George Carlin
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
bryanwood74
Sep 24, 2015 09:50 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
