toggle switch for lock-up converter.
I kno I dont have an F-body, but it should still work, right? I tried following the instuctions on this page https://www.thirdgen.org/newdesign/t...ueswitch.shtml but they aren't detailed enuf "hook up a wire to terminal a and f and tho the two connectors on the switch and TADA!! youre done" just doesnt cut it. can anyone explain it better? I have a three prong switch with supply volts, on acc., and earth ground. What wire from each do I hook to where?? TIA
[This message has been edited by midnightblus10 (edited July 18, 2001).]
Car: 04 GTO
Transmission: M12 T56
You can't use a lighted switch for this as you are switching a ground. If you want to use that swicth anyway, you hook the 2 wires to the power and accessory terminals of that switch. It doesn't matter which to which.
