Anyone with CB on Camaro?
Old Jul 23, 2001 | 02:33 PM
un4givin89's Avatar
Alright, I installed my cb, and have one of those magnet mount antenna's. And I get some bad engine interfreance. I've been told those aren't the best antennas and that you have to get the thing in a certain postion cuase it uses the cars body. Anyone else have a cb installed? Where did ya mount your antenna?
Old Jul 23, 2001 | 03:29 PM
manuel's Avatar
My friend has a CB in his Surburban.He has no interfreance.Mount the Ant. on the back of the car...maybe that will help.
Old Jul 23, 2001 | 03:42 PM
un4givin89's Avatar
no, differn t body car, back won'd help
Old Jul 23, 2001 | 10:07 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Try making sure you have a good chassis ground from the battery if you're getting engine noise. Magnet mount antenna's only use the body of the car to stick to (thus, the magnet), not reception.
I don't personally own one, but a freind of mine had a mag mount that seemed to not be affected by it's position (which, it is mounted to a moving object, one would think position wouldn't be a big factor).
The mind is like a parachute, it only works when its open
Old Jul 24, 2001 | 08:57 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I put a CB in my Z for a trip I made a few years ago. I used the type of antenna that the base sticks to the glass on the inside, antenna mast sticks to the glass outside, directly opposing the base, of course. I mounted mine at the lowest point possible, center, on the rear hatch. It seemed to work pretty good. If your hatch is tinted, then you'll have to remove the tint where the base would go, and consequently leave the base in place since you'd have a square hole in the tint if you were to remove it... mine is still in place, even though I never use a radio anymore...
KAM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
