Where is computer 87 IROC 5.7? Stripping one for my 305 IROC and want the computer
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It 'should' be under the dash on the pass. side. Drop the under-dash panel, then it's just behind the face of the dash.
The line is the dash face
YOU | ECM
It's 'usually' held on with velcro to the back of the face. Just give it a good "YOINK" and it should come out.
AJ
YOU | ECM
AJ
Hey, thanks a lot I thought that it was on the pass side.
Is it worth taking Rear off car? around 130K miles on it... I have a mint body 89 IROC and jusy want to get everything I can but I need to get rid of hulk soon
Need any parts?
Got tail lights, mint
spoiler, complete
rear bumper excellent
Need any parts?
spoiler, complete
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Originally posted by eddie938f
the chips may be different from the 87 to the 89 so make sure they are same before plug it in or your fry your system &undo your ground before u do anything
Car: 84 SVO
Transmission: WCT5
Originally posted by irocz38
Thanks for all the info guys, anything else I should get off the car?
Wire harness is totally cobbled and hacked, I will take disc rear3.42 posi i think.
-Irocz38
-Irocz38
Never thought to cut off all the connectors, I did keep the injector harness, and the relays for the fans, fuel pump, etc.
Thanks a lot for th eadvice, any help is always appreciated.
Any idea if the wire harness is the same for 305 vs. 350 ???
-IROCZ38
-IROCZ38
Car: 84 SVO
Transmission: WCT5
[B ]
-IROCZ38 [/B]
[B ]
-IROCZ38 [/B]
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
