tpi -> carb wireing problems
Old Aug 23, 2002 | 12:03 AM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
hi, i am currently changeing from tpi to carb. i sliced all the wires leading from/to the ecm and now i am faced with a problem. several things will not work. my car is an 89 trans am GTA and almost everything went through the ecm as far as i know. i cant get my starter motor to work. there are around 6 wires comeing from it and i have no idea what they do. the big one is obviously the negative terminal to the battery, but what about all those little ones on the other screw? my key has a chip in it and i think the starter wont work unless the ecm detects it. the haynes manual says a yellow wire is what comes off the ignition on start but it goes straight to the tranny. can anyone here help me wire up my starter? ive spent a very long time on this problem and the yellow wire only seems to have voltage when its on accesory power and not on start. is there a web page somewhere with a decent wireing diagram of my car?
Old Aug 23, 2002 | 02:25 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is a starter disable relay that is controlled by the ECM that will have to be bypassed. The relay is located under the driver's side dash.
Old Aug 25, 2002 | 09:08 PM
Psyte's Avatar
relay
where under the dash is it? what does it look like? is it in/near the fuse box?
Old Aug 27, 2002 | 10:38 AM
The relay is against the fender wall, up above the fuse panel. It has a pink wire, a blk / yl wire, a yellow wire, and a dark green wire going to it. Connect the yellow and dark green wires together to bypass the relay.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
