digital dash question
Old Aug 8, 2001 | 02:55 PM
rudys119's Avatar
I have a 87 gta with the digital dashboard, i have some type of problem with my tach for some reason whenever it gets hotter out the rpms just start to gradually rise till it just fills up the top and shows that im redlining when my rpms are actually at their normal state. It only seems to happen in the middle of the day when it is hottest out.
87 GTA 350 TPI
Mods: K&N Air Filter, New rocker arms, Stage III chip.
Next Mods in line: Exhaust, headers
http://www.geocities.com/rudys120/transam.html
Kills:
87 Mustang 5.0,
89 Mustang 5.0 (modded)
?? Iroc
00-01? Jaguar driven buy 85 yr old guy
Too many ricers to count......
Old Feb 3, 2003 | 01:24 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
that happened to me too, but it wasn't hot out at all. all of a sudden i look at the dash and i see i'm redlining at 25 mph lol. then it just stopped and it hasn't happened since.
Old Feb 24, 2003 | 08:35 PM
355formulatpi's Avatar
I get the exact same thing!!!!!! It is winter, and the more i run the heat, the quicker it does it!! How do we fix it!!!!!!
Old Feb 25, 2003 | 06:06 PM
87TAGTACANADA's Avatar
The dash in my 87 gta does the same thing with the other guages (temp,voltage ect.)I think it maybe just a bad or dirty connection between the dash and the connectors behind it.
Old Feb 25, 2003 | 07:26 PM
Mine is deffinatlly iniated by temp!!!!!!! Like an electronic component is out of tollerance when it gets hot!! Later!!
Old Mar 1, 2003 | 12:00 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
My tach in my GTA just reads exactly twice what it should be. Any ideas on how to fix that???
Old Mar 1, 2003 | 10:05 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
yes, get rid of the digital dash.
J/K
you need to have a scan tool put on to see if the computer is reading the odd rpms or if it reads normal. if they are normal, than the problem is from the ecm to the dash. if the computer reads odd, (wich is more likely) your modual on the distributo may be on the way out, because it is what sends the rpm signal to the computer.
good luck.
thanks
anthony
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
