Horn Question...
Old Feb 28, 2003 | 11:27 AM
68Beater's Avatar
Horn Question...
When i purchased my vehicle, the horn did not work because the contact inside of the steering column was gone. What i am wondering is, where does the contact go? Does it connect into the turn signal/hazard assembly? I see a black or brown wire that connects to a metal contact, but there is nothing connected to that contact. Any help would be appreciated.
Old Mar 1, 2003 | 10:13 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
do you mean the sprig loaded wire contact **** are broke (it plugs into the t/s switch)? if it is broke, then you will need anougther plastic clockspring plate (the white piece that the horn contact rubs withthe tit sticking out).
thanks
anthony
Veaceonee
Sep 29, 2016 08:15 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
happyhapka
Aug 15, 2015 04:42 PM
