Need Help! Speedometer problems!
Hello,
I mentioned this problem before, but I have a speedometer problem. I just never ask this question. Ok, sometimes my speedometer is not working and sometimes it does. I mean, when it does not work it either goes off, or fluctuates. I dont know much about these things, but could it be the cable? If so can I replace it, or check it to see if maybe its too loose? Also, where is it, if possible can you give me a picture and show me exactly where it is?
I am referring to under the hood, I figured I would try that instead of tearing the dash off, which I REALLY dont want to do because I will not be able to get it back on heheeh.
Help please!
brian
91 Camaro RS V6 Coupe
Help please!
brian
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I don't think the 91's were cable driven. I think they were purely electrical. Pull the guage fuse and see if it operates at all. If not, its electrical. Could be a loose connection somewhere. Also, if you don't want to drive with no guages, look at the transmission and see if you have a cable running from it.
yeah, trace back to / from the vehicle speed sensor. it's a round thing that plugs into the transmission (if i remember correctly, it's been 6 years since i took it out). on my 87, i think it was a black & green wire on the plug. and not having that sensor in the loop can do some serious harm to performance/mileage since the computer doesn't have an accurate speed measurement.
Hello,
Ok, if it is electrical, and I were to pull the gauge fuse out...which would not be a huge deal cause I mean the important one right now to me is the speedo (I would not go a while not using the guages though.
But, anyway, if it is electrical what would I do? I mean, is there something that would need to be replaced?
Brian
Brian
GeneralIesrussi
Sep 3, 2015 03:23 AM
