running fan switch
Old Aug 10, 2001 | 06:55 PM
boogada186's Avatar
running fan switch
I want to run a toggle switch to the fan on my 86 Iroc and I know how to wire it, the problem is I don't know how to get the wire through the fire wall. Where is the best spot to run the wire. I would like to find an already existing hole but I will drill if necessary. Thanks
Old Aug 10, 2001 | 07:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you have cruise (even if you don't it should be there still), pull back the carpet behind the brake pedal, there is a grommet there, it comes out underneath the brake booster.
The mind is like a parachute, it only works when its open
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
