Weirdest electrical problem known to man
I have a 91 Z28 TPI 305 700-R4, Now the problem is when the battery is disconnected for some reason (on purpose) I will reconnect it and the car will not crank. The starter solenoid will rapidly move the starter gear back and forth but will not turn. It has done it with 2 different starters so I know that the starter is not the culprit. It doesn't do it everytime however. After spending countless hours trying to hunt it down I can turn up nothing. When I disconnect and reconnect the terminal again to look for a problem, the car will mysteriously start, even if I didn't do anything but disconnect and reconnect the cable. The terminals are clean and the battery is good. I think that it has something to do with the ECM. If you could shed any light on the problem I would greatly appreciate it.
Its not the ECM. You can completely remove the ECM from the car and it should still turn over normally. If the starter gear is moving back and forth, then the ignition cylinder is doing its job of sending the low current voltage to the solenoid. If its not a problem with the battery or the power and ground connections, it must be in the starter/solenoid. When you tried the two different starters, was it also two different solenoids or did you put the old solenoid on the new starter?
I used 2 different solenoids. When I pulled the ECM fuse it wouldn't even engage the starter gear. I know the solenoid is good because I removed the whole starter and tested it to be sure. I am driving the car now with no problems what so ever. It just did it when the battery was reconnected.
Car: "02 z-28
Engine: LS-1
I know it is not the shims because when it does finally start it cranks fine. I also have a high torque mini starter and I can pull the starter gear out by hand and was able to check the alignment with the flywheel. everything is good there.
TRY THE CABLE THAT GOES FROM THE BATTERY TO THE STARTER,IT MIGHT BE CORRODED IN THE INSIDE AND LOOK FINE OUTSIDE,SO IT MIGHT NOT BE GETTING ENOUGH JUICE,YOU KNOW WHEN YOUR BATTERY IS ALMOST DEAD AND YOU TRY CRANKING YOUR CAR....IT DOES THAT SAME CLICK...IT PROBABLY AINT GETTING ENOUGH JUICE SOMEWHERE...SORRY IF I WASNT MUCH HELP
I think I am just going to replace all the battery power cables. It is possible that there is corrosion in them. I like my engine compartment clean and I wash it pretty often.
Car: "02 z-28
Engine: LS-1
Perhaps the battery cables weren't in tight enough. Don't laugh, it happened to me, once. For whatever reason, the lights and everything would come on in the ACC position, but trying to start the car would produce nothing. Just a thought
Hey CaysE I have done that too. I felt like the biggest idiot after spending hours looking for something when come to find out it is just a loose battery cable. I know it isn't the problem in this case. It only does it when the power is hooked back up, and it doesn't matter how many different ways you hook it up. I have unhooked it and hooked it back up probably 20 times and just out of the blue it will decide to crank. Once it cranks that first time you won't have any problems until you unhook the battery again.
Car: "02 z-28
Engine: LS-1
Yeah I have VATS, Is this problem some how associated with it?
Dan, Thanks for your help. What your saying makes a lot of sense! I would put my money on the VATS being the problem. I can live with it if it is that expensive. It just one of those things that can be a pain while you working on it. When it acts up and doesn't crank the solenoid on the starter is moving the starter gear so fast (clicking) that there is no way it could be a lack of voltage. That is why I thought it was ECM related. Again thanks for all your help! -Jon-
Car: "02 z-28
Engine: LS-1
-If you get any action at all from the starter solenoid it is NOT anti-theft related. I would get a voltmeter and start looking for large voltage drops going to the starter. I would have to agree with the other guys, something else is amiss. Gotta lay off that high-octane Comfort. LOL, dan So basically if it was the VATS the starter will not do anything right? No solenoid cycling? So I should go back to those time honored traditions of looking at the power cables huh? Thanks for your idea anyways.
Axle/Gears: 3.45, 3.27, 3.27
It's not the VATS. If it were a VATS problem you'd get nothing, no click at all. The solenoid isn't getting current. You've got the battery cables and their connections to check. A few local Members have had a problem with the terminal at the solenoid breaking. The connection appeared tight, but the stud had broken inside. The stud would turn freely. After you got it solved, spray the terminals with battery protectant.
Lon
Lon
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
ON the VATS it's 3 MINUTES not 15 if it detects any tampering and it will light up on the dash "SECURITY" if it's blocking you. If after 3 minutes it detect tampering again it will make you wait another 3 minutes
BlackphantomZ28
Aug 22, 2015 01:00 PM
db057
Aug 11, 2015 10:11 PM
