Tach Problems need help plz w/n
Old Aug 8, 2001 | 08:29 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
When I stomp on it or rev it up the tach only goes up to 3000 and jump back down and up , but no higher. What up with that can anyone help. Thanks for any info.
Old Aug 9, 2001 | 09:54 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
Hello com'on someone must be able to help me. Is the wire grounding out?
Old Aug 13, 2001 | 10:51 AM
Zelda1's Avatar
Car: 1984 Z28 & 1968 Camaro
Engine: 350 & 355
Transmission: 700R4 & TH350
I have a similar problem with mine but a little worse. Mine when I turn on the headlights kills my tach and oil guage. However if I turn my dash lights OFF they come back. I have traced mine out to be the plastice wiring on the back of the cluster. Try checking the Ohms cross the ground feed of it. See if that is where you are loosing the feed.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
