Engine wiring.... starter?
Old Aug 13, 2001 | 02:43 AM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
Ok I was driving the Z around today, hit a hill .. all of a sudden the damned thing dies...
Takes me a while to figure out what it was (bout half an hour) ... the wiring for the starter came loose and since my engine bay is a complete rats nest... I don't know how to fix this
I know my starter is screwed but it still works fine when it catches...
Any suggestions on re-wiring the engine bay?
Old Aug 13, 2001 | 11:39 AM
TransAm383's Avatar
You can do what I did and just get a new enginer harness. It has the wires for everything in the engine bay. Its real easy to do. I was a bit worried when i started cuz I dont know much about electricity but it was a snap. The harness "plugs" into a unit behind the brake booster and just dort of drapes itself across the back of the motor, down through the fender and into the ECM. Just do yourself a favor and get the harness for your exact car. I took a harness from an 84 Z-28 and used it in my 84 Trans Am. I had to swap wiper motors cuz the two were different. The heater control wires were a little different too. You can get a harness like this for less than a hundred bucks. Hope this helped.
Old Aug 13, 2001 | 03:06 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
hrm, I don't have the ECM and crap... there anything I can get that doesn't have wiring for one of those?
no a'/c, no smog, nothing like that... I just have a lot of wires that don't go to anything... have some on both sides of the engine that just look dumb n stuff... few have actually melted, POS's... lol
any advice on just clipping the hell out of things and disconnecting the ECM wiring part?
I can't really afford a new wiring harness, since I'm probably going to get one for my dash soon...
Old Aug 13, 2001 | 04:36 PM
GuyRicardo's Avatar
Need to know more about you're car. Sound like you're running aftermarket carbs and distributer. If that's the case, I would suggest getting hold of a good wiring diagram and systematically getting rid of anything that does go to the ignition/charging system or gauges. There was another post I saw last week that had wiring diagrams from an 85 camaro service manual.
Old Aug 13, 2001 | 04:41 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
83 Z28
350
Pertronix HEI Vacuum Distributor
Edelbrock 1407 750 cfm carb (manual choke)
I just need to know what I can pull and what I can't... the ECM is gone, I blew it up (Literally, M500's are fun)
I can sort of trace part of the harness from the ECM but wiring on a car isn't anywhere near my strong point... I'll try to get a picture or two of the mess under my hood...
Old Aug 14, 2001 | 12:39 AM
Changa2's Avatar
Check this thread out. I'm sure it will be of some help.
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
