Wipers gone wild
Old Aug 29, 2002 | 05:36 AM
88bluebird's Avatar
Wipers gone wild
Every time i put the tilt down all the way, my wipers kick on. It'll go through one cycle and stop. If i hit a bump, it'll kick on again. It used to only do it in cold weather but its doin it all the time now. If I lift the tilt one notch, it wont do it, but i'm not comfortable drivin like that. I know somethin is gettin shorted and im probably gonna have to replace it. My question is, am I gonna have to replace the whole turn signal switch or is it it's own seperate peice???
Old Aug 30, 2002 | 04:26 PM
2vmodular's Avatar
look at the wiper switch connector at the base of the steering column. if the problem isn't there, try replacing the wiper switch in the column.
turn signal switch is not too expensive and it has to be removed to replace the wiper switch, so you may wish to replace it while you've got the column apart anyways.
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Marc Brown
Sep 28, 2015 01:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
