No Battery power to Radio
Old Aug 16, 2001 | 11:35 AM
greyZ's Avatar
I've taken out the stock radio, which wasn't working, and I'm going to install my Alpine CD deck. I've test fitted it and it will work, but, there is no battery power in the radio leads, to supply the constant power.
I have ignition power, but both the grey and black leads work as a ground.
Whats going on here?
1985 Z28
305 LG4/700R-4
bone stock right now
Old Aug 16, 2001 | 03:08 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I would assume you are talking about the power to battery that helps the deck retain memory? I have found that some early model cars haven't got an auxillary power because the original tape deck didn't need it... If your tape deck didn't have a clock, then chances are that you wont have auxillary... I don't know if any f-bodies came without a clock... I've only seen this on an '85 CRX. I had no problem hooking up my AIWA CD player to my '84 in sig. You may want to go find a wiring harness from the junk yard...
If you haven't already, you might consider buying an adapter kit for your car which might provide a solution, at worst you're out $30 for a much cleaner install.
People feel free to poke holes in my knowledge, I've only installed 4 CD players...
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!!
First Kill: 2001 Subaru Impreza WRX Wagon (1 person vs me with 2 passengers)
[This message has been edited by ChillPhatCat (edited August 16, 2001).]
BRoss99
Aug 10, 2025 05:08 PM
colton_carlson
Mar 8, 2019 12:21 PM
sailtexas186548
Aug 24, 2015 10:11 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
