Wide Band O2 Sensor Circuit
Old Aug 17, 2001 | 07:00 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is a post on the DIY PROM board titled "DIY WB is here" that discusses a wide band oxygen sensor circuit / system that was designed by a group of guys at www.diy-efi.org. If you are interested in building the circuit, there is a group purchase going in for a lot of PC boards that will be closed on 8-24. If you are interested in ordering a PC board, fill out the form at http://208.37.117.207/wb.html and submit it. The cost of a board will be approximately $9 & they will be shipped out around 9-10.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
[This message has been edited by Tim Burgess (edited August 18, 2001).]
Old Aug 18, 2001 | 07:45 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
What will a WB O2 sensor do for me? Or anyone? I guess I'm asking what benifit it will give us.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Aug 18, 2001 | 10:43 AM
John,
A wide band O2 sensor has the ability to indicate A:F mixture ratio accurately over a wide range (10:1 to 20:1, for example), which is very useful in tuning. The O2 sensors used in our third gen systems are narrow band sensors, which are only accurate near the stoichiometric ratio (14.7:1), and may only be used to determine if the mixture is rich or lean, and where the transition point is.
Tim
Elephantismo
Feb 13, 2019 12:51 AM
9192camaro
16
Feb 3, 2019 12:21 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
