Rear Hatch Motor & Engine compartment Wires
Old Aug 16, 2001 | 06:23 PM
nj88v6's Avatar
Hey Everyone,
Can't seem to get the rear hatch to close. I checked all the fuses, none of them are blown. Was wondering how I can test to see if the actual rear hatch motor is blown or if it is possibly something else like wiring. Thanks for any help.
also, anyone know where I can get the wiring connector ends that are in the engine compartment? Many of those plastic clips have snapped so they won't stay snug together. Right now, I am using tape to hold them together. I am actually concearned about the ECM bypass one. Since you have to disconnect it and reconnect it for diag, it's plastic clip has snapped and I am scared that there may be a bad connection if it doesn't stay snug.
Thanks!
Old Aug 16, 2001 | 09:33 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I can't tell you about the hatch part, but most OEM harness connectors are available in the 'HELP!' section or the electrical section of the coorperate chain auto part stores
Old Aug 17, 2001 | 02:25 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Is there 12V to the motor?
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
[This message has been edited by lonsal (edited August 17, 2001).]
Old Aug 21, 2001 | 05:22 AM
Duffster@Work's Avatar
If you remove the motor (3 big bolts) from the rear of the car and take it to the front (don't forget to disconnect the wires) you can test it directly on the battery. the key here is to depress the little black switch in the top of the assembly to simulate having the hatch come into the shut position. The switch is in between the humps below.
Yes, there is a full 12 Volts to the rear hatch motor.
(Currently in Pattaya Beach Thailand)
E-mail me wwixon@vinson.navy.mil
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
[This message has been edited by Duffster@Work (edited August 21, 2001).]
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
