Keeps blowing the fuse (int. lamp / horn)
Old Aug 21, 2001 | 02:59 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I tell you this is just my luck. I put my 1992 RS back on the road yesterday and come to find out the horn and interior lamps don't work. Well that is just great because I have to take this through inspection and that is one of the things they check.
I went to the fuse panel and located the fuse that runs those to things. It was blown so I installed another one and it imediatly blew as well. I next tried a fuse 2 sizes larger and it blew that one also, and it happens the second the fuse is plugged in.
I hate electrical problems, so could someone give me some suggestions for me to do. I don't have any manuals with wiring diagrams, but I do have a test light and multi meter, so any help would be greatly appreciated.
Old Aug 21, 2001 | 04:15 PM
Brent's Avatar
If I'm not mistaken the cigarette lighter is on that fuse. Try unplugging the socket, sometimes they short out.
Old Aug 21, 2001 | 04:46 PM
Car: 1992 Camaro
Engine: 350 miniram
I thought about that also, and I did take the socket out, and it is still blowing the fuse. Anyone else have some suggestions for me?
Old Aug 21, 2001 | 06:17 PM
Car: 1992 Camaro
Engine: 350 miniram
Update:
I unpluged the cigarette lighter wire, and then I removed the dome light bulb. I then installed another fuse and my horn worked. Next I installed the dome light and then both the horn and light were working. I finally went to install the cigarette ligher wires with the fuse installed and it blew. I only have one fuse left so, for now the lighter is unpluged and my horn and interior lamp is working.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
