closed loop or not???
how can i tell if my car is going into closed loop or not? i changed my thermostat and now my car is running rich. i was told that a 160* thermo was too low and that my car doesn't go into closed loop. is this true? thanx
'88 CAMARO 305
OPEN AIR ELEMENT
FLOWMASTER CAT BACK EXHAUST
COMPUTER CHIP
HYPERTECH 160* THERMO.
'88 CAMARO 305
OPEN AIR ELEMENT
COMPUTER CHIP
You should still go into closed loop with that thermostat. To check for open/closed loop, run the car and ground the ALDL,like when you check for trouble codes. One flash per second is closed loop, while 2 per second is open loop. Keep in mind that if you sit at a light for a while, or idle, you may go into open loop.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 5151 150HP kit
thanx man. for the aldl thing i use the #5 and 6 ports, right? top right?
'88 CAMARO 305
OPEN AIR ELEMENT
COMPUTER CHIP
'88 CAMARO 305
OPEN AIR ELEMENT
COMPUTER CHIP
Pac J
May 17, 2020 10:44 AM
