Drove over Bump, Radio Station Changed
Old Aug 21, 2001 | 09:41 AM
GTA88's Avatar
I drove over a bump yesterday and the radio changed a few points on the dial (digital, of course), and the "fade" adjustment was being displayed, as though the radio thought I pushed the fade control button.. I reset it to the right station, and it was OK. It's a stock radio, I think. No add-ons.
Wiring coming loose ? Radio starting to wear out on me ?
Thanks, GTA88
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Aug 21, 2001 | 12:25 PM
ATOMonkey's Avatar
Mine did the same thing. I had no idea what was wrong with it. Towards the end when it was getting real bad, I'd scan for a station and it wouldn't pick up anything unless you kicked it a couple of times. There had to have been a loose wire in there somewhere. I just never found it. I even had it apart a couple of times, but never saw anything out of the ordinary. I just put up with it long enough to save up for a good radio.
Old Aug 21, 2001 | 04:48 PM
GTA88's Avatar
ATO,
Yeah, must be a loose connection, maybe inside the radio itself.
GTA88
Old Aug 22, 2001 | 02:14 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Its the Gremlins I tell you, if they dont like the music your listening to or whatever their mood is then they will mess with it or change it to something totally different.
But seriously sounds like a loose (or getting that way) soldering connection, they are really hard to spot even if you take it apart unless its so bad you see black marks from it sparking internally you may be able to see them with a good magnifying glass but if your going to bother, save yourself the hassle, and save up for a good stereo, just make sure to get an alarm or something, I put a really nice Pioneer in mine shortly after I moved here, someone else ownes it!
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. Found a guy who can build me a ford 9" (yep sorry guys) for less than 500 then comes all the goodies such as disk brakes so on and so on, will it ever end?? I hope not!!
Old Aug 22, 2001 | 01:24 PM
GTA88's Avatar
The Gremlins usually switch it from heavy metal to classical music. From what I hear, it's hard to find a radio that will accept the steering wheel controls, and if you did, it would be expensive, so I am probably going to have a cheapo cassette / fm stereo put in, when and if my current radio gets too hosed up. Less to worry bout ! It's the power I crave more than the sound, anyway....
Ghettobird52
Jul 5, 2024 11:18 PM
Zachattack0925
Aug 12, 2015 09:52 PM
