what gauge wiring is going to IAC. GM service reads .8
Old Aug 24, 2001 | 09:48 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
any help appreciated, i need to know so that i can order the pins and seals to the connectors i bought. so that i can make piggy back connectors for guys switching from small block throttle body injection units to big block ones, that have different iac connectors.
turbo city sells em, but its over 1000% markup.
thanks.
Old Aug 24, 2001 | 10:42 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
18ga wire
Old Aug 24, 2001 | 12:10 PM
snflupigus's Avatar
that a guess or positive answer?
Old Aug 24, 2001 | 01:44 PM
deadbird's Avatar
Engine: TPI 305/ v6
If it makes you feel better to have solid info,,,
milimeter wire gaging system
represents diameter of solid wire in mm or cross-sectional area of stranded wire in mm^2 (square mm).
conductor size 19 AWG
area 0.800 mm^2 (square-mm)
area 1579 CM (circular mil)
diameter 45.9 mil (1)
diameter 1.166 mm (1)
DC-resistance 0.022 Ohm/m
tensil strength 24.00 kgf (2)
weight 7.112 kg/km (Cu)
weight 2.160 kg/km (Al)
construction: stranded
Note: lay factor of stranded conductor is assumed 2 %.
Note:
1. diameter of stranded conductor is an approximation.
2. tensil strength of crimped terminal is about 60 % of conductor.
.822 would make 18ga
.651 makes 20ga
Hope that helps
[This message has been edited by deadbird (edited August 24, 2001).]
Old Aug 25, 2001 | 11:20 AM
snflupigus's Avatar
well, i know there are people that respond that are "sure" and then there are people that respond that know. But thanks a ton, sorry if i sounded rude, or made it sound like i didnt trust your answer. Thanks. I just needed to be 100%, before i go buying 40 pins and seals for these weatherpack connectors.
Old Aug 25, 2001 | 04:09 PM
deadbird's Avatar
Engine: TPI 305/ v6
It's casual, I wouldn't trust me either
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
