gauge cluster
gauge cluster
I have "idiot gauges" with no needles , which i hate. I have a 85 camro w/ the 2.8 and no tach. And i have a 86 camaro 2.8 parts car, which has the needles and a tach. Will the cluster w/ the tach work in my 85. And will the tach work to? And will it just plug in or do i have to splice sum wires?
Tim
[This message has been edited by 85maro (edited August 27, 2001).]
Tim
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes, you can swap them out directly. No wiring has to be change but, you need the proper sensors for the water & oil gauges to work,, the idiot light sensors will merely cause the gauges to peg out.
* a warning, as I have experienced, the replacement temp sensors are very inaccurate giving a overly high temp reading making one paranoid the car has a severe overheating problem. If possible, get on OEM sensor from a donor car.
OEM has a button (round) terminal
Replacement has a male spade terminal on it.
On my firebird, the temp is pushing over 220° w/out the 180° stat having even opened yet.
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited August 28, 2001).]
