starter wiring! help me!!!
Old Sep 5, 2002 | 02:21 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Recently I wired up a push button to start my car to by pass the chip in the key. Which was working fine for about a week or so, until the starter started to click, and then i lost all voltage. I followed the wire I made and I think it shorted out onto a ground cause it was partly burned by a header. So I rewired everything the right way, and now the starter just clicks. So I thought i had a bad starter and I had it tested and it turned out ok. So I checked my voltage going from the hot wire that goes from the battery to the starter to see if its 12 volts, turns out it is, so then I check the voltage at where the key wire goes to the starter, its 11.5. From what I hear, it needs 12 to start, and that might cause the clickn. Im thinking is it possible that I shorted out my battery? Cause after I try and start it, I lose all my power for a while. Any help would be appreciated thanks!
Old Sep 5, 2002 | 09:01 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
try jump starting it and see if that does the trick but it sounds to me that your battery went south for the winter a little early this year.
Old Sep 9, 2002 | 09:56 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you can test a bad battery and get 12 volts, you need to test it with load. it sounds to me you just ran it down with a shorted wire. once you get the battery recharged you should wire in a 30 amp relay and fuse so it doesnt happen again
Old Sep 10, 2002 | 01:31 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
yes you guys were right I got my battery tested on a load tester at my budys marina and it was complete junk not even funny. Your probably right my quick wiring made for a shorted out battery. Thanks for the help guys!
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
