Radio only works when I hit a bump?
Old Aug 27, 2001 | 06:43 PM
loc0bob's Avatar
Well I just bought a new Trans Am and it came with a tape player(yes this weekend it is getting switched out for a cd player).Anyway the tape player and the radio were working fine until one day it started raining.Now the tape player or the radio wont work but whenever I hit a bump it will work for about a second and then stop.I took it out and looked at the back and everything is hooked up and I have no idea what is going on.It is turned on and has power to it but it seems like it is just dead air.Anybody have any ideas?
Old Aug 27, 2001 | 08:47 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
sounds like a wire is either loose or grounding out on something metal somewhere. lol sorry i cant be of much more help.
Old Aug 30, 2001 | 02:21 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
That is a loose ground wire. Most radio's have a chart on the back for the wiring. The ground is usually the BLACK wire. Just remove the radio again and trace the wire. If it is not connected to the body's metal the radio will not work. If it is connected then you have a faulty wire internally and may need to replace the radio. I bet it is the ground. Also speakers have grounds (Plus and minus wires actually) too so check those also. My left dash speaker was not working for a long time. when I replaced my dash pad I found that the speaker wiring was loose or not grounded. Once I fixed that my radio played great.
86 Camaro Black SS Coupe, T Tops, ASCD Daytona Twin Turbo hood, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
'91 RS 5.0 TBI = Waiting to be modded, but has all of the toys inside.
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
[This message has been edited by 86NiteRider (edited August 30, 2001).]
Old Aug 31, 2001 | 06:56 PM
jijiandfarmgang's Avatar
Hey,
It wouldnt be the ground because it wouldnt turn on but just not play music. Ive seen some decks do some crazy stuff. Its just a ac delco junker. I hate those things they always break on me. The lights go and no music comes out. Anyways the problem is something interal most likely a short. Not a bad ground. If you took it out and beat it a few times it might work ( i only say this cause your probably gonna junk it anyways). Hope this helped
Old Sep 2, 2001 | 10:36 PM
loc0bob's Avatar
Well I found the problem...
One of the wires that is hooked up to the left rear speaker was touching some metal so I just pushed it off the metal and now it works fine.
Thanks for everyones help
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
