cooling problem
Old Sep 7, 2001 | 09:28 AM
MSTNG KLR's Avatar
cooling problem
I have a stage two hypertech computer chip, with a dash mounted switch for and extra electronic fan. I have heard that the chip runs better when the car is cooler, how often should i use the switch??
Old Sep 8, 2001 | 04:16 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Some chips are programmed to make the fan turn on at a cooler temp anyways but, to answer your question, use the switch as often as you like. Some people just ground out the relay permanently to have the fan run right from start up.
The mind is like a parachute, it only works when its open
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
masonta
Sep 1, 2015 06:40 PM
