electric fans how hard and how much more horse???
Old Sep 6, 2001 | 12:30 AM
speedfreaker's Avatar
i want to change out my cheasy flex a fan on my 83 transam 4 an electric everyone says it works better and frees up some power from my engine and i was just wondering how hard is this how much time does it take and is it expensive oh also is their any special adaptors or equipent needed ???
CHRIS
1983 firebird transam
Old Sep 6, 2001 | 01:48 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Here is a wiring diag for the factory wiring of an elec fan.
http://www.deadbird.org/tech/fan.gif
Instead of the ECM controlling the relay ground you will want to get a thermo switch like the ones made by JET or Hypertech
Available at JEG's or Summit for under $40.
The switch screws into the passenger side head and take the place of the ECM in your case. You will want some sort of fuse on the power wire just for safetys sake.
The other route is a switch the Summit sells (forget the manuf. name) that is adjustable. A probe sticks in the fins of the radiator & the rest is wired in a similar fashion to the above diag. (I have one on my camaro).
For my camaro I got an elec fan out of a Dynasty from the junkyard for $10,, a little cleaner look might be getting one from the correct car or an fatermarket elec fan, depending on your budget.
Horsepower,, to guess would be anywhere from a 5-15 gain but, free power is free power. You'll notice at the least the engine will be more willing to rev a little quicker in neutral & your gas milage should improve a little as well (unless you have an LG4 ).
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited September 06, 2001).]
Old Sep 8, 2001 | 04:39 PM
89Irocz23's Avatar
when I had my Ta a few years ago I took my fan off and put electric on and noticed some what of a difference, but it actually ran hotter. I guess I shuld have used dual fans.
64goatman
Sep 9, 2015 01:09 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
z28guy134
Sep 1, 2015 11:50 PM
