Cluster Swap
Old Sep 9, 2001 | 09:23 PM
89-28gp's Avatar
Car: 1986 Firebird
Engine: not stock 2.8
Cluster Swap
I was wondering what would be involved with swapping the cluster out of my '86 Bird, which only has the speedo, gas gauge, and a bunch of dummy lights, for a cluster which has the above plus a tach, and all the gauges (volts, oil pressure, temperature). Will the new cluster just hook up & plug in in place of my old one? Do I need to change any of the sender units aswell? Thanks
Old Sep 9, 2001 | 09:46 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I believe that anything out of an 82-89 firebird has the same mounting... just make sure you get a cluster from a donar car with the same number of cylinders and that if your cluster is cable driven then get a cable driven cluster and if it's digital, get digital... you'll know what I'm talking about as soon as you try to pull the cluster to inspect it (cable driven is a b*tch to remove)... BTW you should get a repair manual if you haven't already to get details on the cluster removal... its not as intuitive as it should be... took me a couple hours just to pull out the engine light lightbulb... I don't believe that the cluster from Camaros are the same piece, but they probably fit (just wouldn't look right). As long as you get the right replacement, you're talking about a plug in and go mod.
Old Sep 10, 2001 | 02:13 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There should be no problems with a direct swap. No wiring needs to be changed either but, you need the proper sensors for the water & oil gauges to work,, the idiot light sensors will merely cause the gauges to peg out.
(copied to save typing it again)
* a warning, as I have experienced, the replacement temp sensors are very inaccurate giving a overly high temp reading making one paranoid the car has a severe overheating problem. If possible, get on OEM sensor from a donor car.
OEM has a button (round) terminal
Replacement has a male spade terminal on it.
On my firebird, the temp is pushing over 220° w/out the 180° stat having even opened yet.
The mind is like a parachute, it only works when its open
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
