MAF sensor
Old Sep 9, 2001 | 08:14 PM
Faught's Avatar
MAF sensor
Just the other day my 85 Firebird stared to idle real low at stops.. (actually stalled a few times) had a diagnostic run on it and came up with code for MAF sensor. replaced that but it is still running rough at low rpm's. If I disconnect it it runs better. Troubleshot using a GMC manual and it returned me to the MAF sensor. Swapped out another and so far it seems a little better. But am waiting on the check engine icon to flick on any time know... Any suggestions. I checked the wire and connector.. OHM'd them all out and it all checks OK
any help would be appreciated
Old Sep 10, 2001 | 12:34 AM
87tpi420's Avatar
did you reset the computer? disconnect the battery for a minute or so? not positive if this will help but worth a shot
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Sep 10, 2001 | 07:48 PM
Faught's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 87tpi420:
</font>
Old Sep 10, 2001 | 07:50 PM
Faught's Avatar
</font>
Thanks ,, but I tried that .. and YES just today on theway to work it chugged and stalled again.............
Old Sep 10, 2001 | 08:31 PM
ImportsRsloths's Avatar
Better change the MAF relays (burnoff and power) ($9.99 a peice, same part # i think it was MR-44 not for sure though) if one of the relays is bad it will keep burning out the MASS AIR SENSOR.... i burnt 2 on my car so i know....... stupid F*C*ing beechmont towing didnt diagnose the problem right....
Old Sep 12, 2001 | 07:25 PM
Faught's Avatar
Thanks for all the help. i beleive the problem is fixed. Embarrased to say it was a crack in my PCV hose that ran behind the engine. still a little low rpm at stops but much better.. Thanks Again
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
