MSD distributor and Plug question
Old Sep 13, 2001 | 01:35 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Ok, I'm running a 6AL box, GM Blaster coil, harness, and soon MSD 8.5mm wires on a 350 90 formula TPI with 22 lb injectors. The car is my daily driver. I was wondering is upgrading to a new msd-8366 distributor really worth the 290 dollars?
Also I was told on jegs tech line to run 1 temp colder than stock on the spark plugs since I'm useing a MSD setup now. Anyone have any ideas?
Old Sep 13, 2001 | 03:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
IMO there's really no advantage over the stock. I replaced mine w/the MSD because my old dist. was binding & the gear was about cooked. I cerrtainly didn't think it worth almost $300. It would probably be more worth putting the Accel ignition module (110-35362/JEGS)in your old dist. for $44. I've got a total MSD ignition & am running the same platinums I always have w/o problems but, plugs & heat range & all that was never my cup of tea.
The mind is like a parachute, it only works when its open
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
