Blinker problem
Old Sep 14, 2001 | 11:33 AM
TransAm87's Avatar
Blinker problem
My left Blinker just stays on when i signal...But when i use my 4 ways it works fine both front and back...But when just used to turn left....both flashers just stay on??My bulb is good?? What could be wrong
thanks
Old Sep 14, 2001 | 03:01 PM
dbarkley's Avatar
Car: 1985 Trans Am
Transmission: 4spd auto
Did you check the flasher module (the thing that goes "dink dink" dink dink" under your dash)? The emergency signals and turn signals use separate flasher modules due to the number of bulbs they're illuminating. The one for your flashers could be bad. Go under your dash and swap them (if they have the same pinout). The emergency flasher might flash real slow but it -should- flash. If so, that's your problem. Take the unit that you took out and get a new one at the local store.
1985 Trans Am - 305TPI AT
SLP Cat-Back - Welded subframe conns
misc engine mods
Old Sep 14, 2001 | 04:34 PM
IROC&ROLL
Guest
Posts: n/a
Check all your exterior bulbs, especially the rear bulbs. If there is more than one bulb for the blinkers, one of them may be out but the other not.
Most flashers (older style anyway) work on current. The current heats up a bimetal strip which bends due to the heat, which in turn opens the contact. Once the contact opens no current flows so the bimetal strip regains its shape and makes up the contact again. Then the cycle repeats.
So, if there aren't enough bulbs illuminating then the flasher won't flash. I just had this happen on my wifes car. Compare the brightness of your left vs right blinkers, both front and rear. On my wifes, one of the two bulbs for the left rear blinker just wasn't making good contact. Once it was wiggled around some it started illuminating and the flasher started flashing.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
