Tach Replacement
Old Sep 14, 2001 | 06:39 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Tach Replacement
I'm currently in the process of swapping out my 2.8 for a 305 & I know I need to swap the tach for a V8 one, but will a tach from a 'bird/TA work in my Camaro? The local scrap yard has plenty of 6cyl F-Bods but only 1 V8 which is a Bird.
TIA
Don
Black 87 2.8l Camaro
Soon to be 305/5.0
http://photos.yahoo.com/bc/z2point8l...l=fld1&.src=ph
Aka Z2point8
[This message has been edited by CanadianCamaro (edited September 14, 2001).]
Old Sep 15, 2001 | 03:03 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i imagine so, i just replace my tach on my camaro with a firebird in a junkyard. it works fine.
84 z28
http://www.geocities.com/yuelb/Car.jpg
Old Sep 15, 2001 | 08:10 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you wire it in, it will work. I'm not sure how it will physically fit into the Camaro cluster; also you'll have no oil pressure gauge unless you have an auxilliary one somewhere else.
Pete
Pete's Place
HiOutput Tech Page
83 SC..former V6...now 213+k mile LG4/5-speed.. 14.891@95.54
89 Formula..ultimate project car..fast as I can push it with one flat tire
79 Lemans..267/auto..no brakes
My karma ran over my dogma
Old Sep 16, 2001 | 10:47 AM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Why no oil pressure gauge if I connect a 'bird's Tach? does it steal too much power from the oil pressure guage
Old Sep 16, 2001 | 12:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The firebird gauge cluster, since being designed completely different, allowed for an oil pressure gauge seperate from the tach.
The mind is like a parachute, it only works when its open
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
