Pretty new so fuse question, and a few others
Old Sep 15, 2001 | 12:46 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
For one, my dash and guage lights don't work, when I leave my lights on I get the standard buzz noise when I turn it off, but no open door noise, guessing fuse? Then I bought a power front seat and have manual seats, how would I wire that in to function, the finally, the story to this trunk pull down motor. I use the trunk like normal, key it, pull it up, close it. Does the damn thing just pull it down? How to fix it because mine don't work.
Old Sep 15, 2001 | 10:39 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The door buzz, 'chime' (annoying noise), only works if the key is in the ignition. There is a contact, behind the ignition key cylinder I believe, that the key presses against that causes the chime to work when the door is open.
Power seat...
http://www.geocities.com/vtcamaro/Pi...rams/pg252.jpg
The hatch motor, never had to mess w/mine (yet thankfully, maybe someone else can help you there. Try doing a search using 'hatch motor' in the body & interior room.
The mind is like a parachute, it only works when its open
Old Sep 15, 2001 | 11:06 PM
Jza's Avatar
Jza
The chime should come on with the lights if the key is not in the ignition, in addition to coming on if the key is in the ignition with the door open.
Old Sep 17, 2001 | 11:12 AM
Chris Luongo's Avatar
You say your dash panel lights don't work? How about the outside parking lights, the orange and red ones all around the car?
If the parking lights work, but the dash ones don't, check the 5amp fuse at the top of the fuse box. Or, wiggle your dimmer switch around a little...it's the typical GM junk and they don't work too good when they get old.
If all the parking lights are out too, replace the parking light fuse. It's probably a 20- amper, and should say TAIL or something like that on it.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
