Wiring in 89 RS
Old Sep 20, 2001 | 05:00 PM
mat89RS's Avatar
Wiring in 89 RS
Well recently I've swapped an lt1 in my car but I'm trying to figure something out for my fuel pump. What color code GM use for wire witch are giving 12 volt when the engine is running, not the ignition, just when the engine is running. I'm thinking about "Bright Yellow" but I want to make sure .
Also How does a rear defroster switch is working, 4 prong but what's the pins layout
thanks
LT1 POWERED
HEADMANS HEADERS
NEARLY 300 HP.
EATS MUSTANGS FOR BREAKFAST
next mods:
crane roller rockers 1.6
lt4 hotcam kit
airfoil
58MM edelbrock trottle body
new paint (wet look blue)
17' rims with 275 zr 40 and 245 zr40
Old Sep 21, 2001 | 04:18 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The ECM supplies the +12v to the relay for it to close the contact only when the car is running, it's a green/white wire. The main constant +12v is a thicker orange wire going into the relay straight(fused) from the battery.
Rear defrost goes as follows
http://www.geocities.com/vtcamaro/Pi...rams/pg218.jpg
(you will probably need to copy & paste that in your broswer link bar)
Old Sep 21, 2001 | 04:39 PM
mat89RS's Avatar
thanks alot bud for that info .... is it possible to rig the deffoger switch so it doesn't act like a 10 min. timer ??? I want to use it for my radio...
LT1 POWERED
HEADMANS HEADERS
NEARLY 300 HP.
next mods:
lt4 hotcam kit
airfoil
Old Sep 21, 2001 | 05:04 PM
deadbird's Avatar
Engine: TPI 305/ v6
I'm not to sure man since it's not really a switch switch like the one for driving lights.
I'd suppose you could take it apart & replace a resistor or something in the timer control but that's a little out of my league.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
