charging problem!!!!!!! (battery)
Old Sep 12, 2002 | 07:58 PM
cridom's Avatar
yesterday my car stopped and never turn on again
so i used jumper cables with my bro's jeep and it did work but when ever i took the cable out it turned off so i changerd the battery and now its working but my battery guage its going down and its not charging the battery
what can i do please help me every time is getting worst
i can barely turn the car on
Old Sep 12, 2002 | 08:43 PM
J Kylez's Avatar
Probably your alternator. To check for sure start the car and check the voltage across your battery terminals. If you are reading approx. 13 to 14 volts your alternator is good. If it is lower than 12 volts it's most likely gone bad.
Old Sep 12, 2002 | 08:47 PM
cridom's Avatar
my volts are going like in the second line
1 below 13
Old Sep 12, 2002 | 08:48 PM
cridom's Avatar
do i have to replace the alternator or could be n e wires?
Old Sep 12, 2002 | 08:56 PM
J Kylez's Avatar
I wouldn't trust the car guage at this point. If the alternator is getting flaky then the voltage regulation may be off. I would definitely check the voltage across the battery terminals with the car running to be sure.
On the other hand, yes, I guess it could be a wire somewhere but I doubt it. Unless something has been rubbing and one is cut or stripped through and shorting.
Old Sep 12, 2002 | 09:07 PM
cridom's Avatar
the battery is new and how do i check the voltage?????????
my car is working like if the battery were a normal battery and i bet that when the volts get to 0 ill be dead
cuz then have been going down
and how do i check the wires?
thanks man
Old Sep 12, 2002 | 11:41 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
put a hand held voltmeter directly to the battery with the car running if you get less than 13 volts replace the alt.
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
