Interior Lights won't light up
Old Sep 29, 2001 | 10:22 PM
un4givin89's Avatar
Recently my interior lights, the dome and the lights under the dash will not come on. When i open the door or turn the dimmer to the right spot. However the beeping noise still happens when I open my door. I am not sure what cuased this, what should i look for or try?
un4givin89
1989 Camaro Ralley Sport
305 TBI
Edelbrock Open Element
1 1/2 lowering springs
Hooker Shorty Headers
Str8 3inch Pipes No Cat
Flowmaster series 40 muffler with dual outlet.
www.mikekey.net
Old Sep 29, 2001 | 10:57 PM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Sounds like a simple fix, check the yellow 20 amp fuse in your fuse box. Make sure its not blown.
No License, No z28, No Hope.
Old Sep 29, 2001 | 11:06 PM
IROC&ROLL
Guest
Posts: n/a
It would most likely have to be the accessory fuse. Does the cigar lighter and light on the radio (assuming stock) work? Those and what you mentioned are all on the accy. fuse. The ground side of these are fed thru several different switches or straight to ground, so that pretty much eliminates the ground side. The drivers side door switch has 2 contacts, one for the lights and another for the buzzer.
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
