wiring nightmare about to give up
Old Sep 17, 2001 | 10:36 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
i just recently swapped motors from tpi to carb now as for the wiring where the hell do i begin it all looks like spegetti i hooked up the starter alt bat dist. and there is juice going to the dist and starter but when i turn the key nothing i can jump the starter and she cranks can it be cause the computer is hooked up still or something i have no idea about how wiring works like what i need and what i can rip out any help would be great
Old Sep 24, 2001 | 09:15 PM
mckenzie's Avatar
hello, you may have to use a computer that is for a carb? no sure, just an idea. best of luck, tom
86 iroc 305tpi auto. mild cam
Old Sep 24, 2001 | 09:58 PM
Project86Iroc's Avatar
Dont know if you are still trying to figure it out, but heres a few ideas. First, is the car pre-89 or later? If its 89-92, you have a vats column, which will cause a no start condition. Second, if you have just ripped all your fuel injection down, start wiring from the basics. What power accesories do you have? And more important, are the wires to factory gauges still there?? It sounds like your igntion switch lead is interupted. If it is not a VATS column, could be a simple wiring problem. Repost more details and I can hopefully help you more.
Mike
I would love to be there when those Muslim Bastards hit the Pearly Gates and realize they were wrong...
Old Sep 30, 2001 | 04:00 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
it is an 85 z28 still can't figure it out like i said there is juice going everywhere i turn the key and she will crank try the key again and i get nothing at all but still plenty of juice
Old Oct 2, 2001 | 11:51 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Hey Man,
You may have a bad ignition switch...all you need to crank is one wire that goes to the ignition post on the starter solenoid.
Either that or the starter solenoid is on the blink. I had a similar situation and there ended up being a short in the wire from the ignition switch down to the starter...just run a new wire.
Hope that helps...
-Adam
Jorlain
Aug 24, 2022 05:11 PM
jklein337
Sep 19, 2018 06:23 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
overdriv
Aug 20, 2015 03:52 PM
