Dead Short on new motor
Subscribe
Sep 25, 2001 | 10:22 PM
Sorry I *#*&!* up.
I just put my engine back in my car and i have a dead short somewhere. If i put a volt meter on the + battery cable (not connected to battery) and the + terminal on the battery i get 12.5v (the negative terminal is connected). I also have continuity between the + battery cable (unconnected) and the - battery terminal(connected). The alternator and starter are okay and are not shorted out. All ground cables are disconnected from the engine block. Where could this short be coming from? If i have to test each wire how can i do this?
thanks
jake
87 Iroc-Z 350 TPI
Dynomax exhaust
modified MAF & filter box
modified ARAP chip
3-10" JL subs
Eclipse components
[This message has been edited by 87ColdAirIroc-Z (edited September 25, 2001).]
Reply 0
Sep 28, 2001 | 08:57 AM
sounds like my luck. I just put the motor back in and killed a new battery. Slow drain somewhere for me. I guess I get to start disconnecting things to see where it's coming from.
[This message has been edited by jcb999 (edited September 28, 2001).]
Reply 0
Sep 28, 2001 | 10:44 AM
I found my short. a + wire was pinched on the block.
Reply 0
Sep 28, 2001 | 11:17 AM
maybe i will be a lucky as u.. I doubt it.
Reply 0
Oct 2, 2001 | 05:55 PM
same problem here still yet to find where though
1982 black Z-28:
-350 ci w/edelbrock 600cfm
-T5 Tranny
-4.11 rear end
-Blue Racer performance cam
-Dynomax heads
Reply 0
Subscribe
