Ignition Coil Wires
Old Oct 2, 2001 | 03:46 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Ignition Coil Wires
Sorry I'm sure the questions has already been asked, but I couldnt find any answers in the archives. I have a factory coil and a crane ignition 6A. There are now two remaining wires that are going to the factory coil, one orange and one black. The accel super coil I need to replace the stock coil with has a pos and negative terminals only. When I tested the wires with the ignition on, one read 12V and the other 3V. How do I hook up this accel coil????
Ford red 1991 Formula 350. ROH 16in wheels, 1998 Grey Leather, street/strip 700r4 2400 stall, EIBACH springs, Strut tower brace, Poly Bushings
3.73 SLP POSI, 26 spline Moser Axles, mid SLP cam, grear drive, SLP runners, 24# injectors, Taylor wires, Accel Coil, Accel Ignition, B&M Megashifter, K&N conical, AFPR, SLP 1 3/4 coated shorty headers, 3in cat, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 180 stat, SSM SFC's, SPOHN lower control arm adapters, custom burned prom, Hotchkis Lower control arms, Aluminum Driveshaft, ported upper and lower, an assortment of autometer guages, 14 speakers and q-logic kick panels. And this thing is still slow!
Instant Messenger JMatlock88
Old Oct 3, 2001 | 03:02 PM
JMatlock88's Avatar
Car: 1991 Formula
Can someone please tell me at least what the four wires that come into the stock coil do?
Old Oct 3, 2001 | 03:27 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The functions of the stock wires going to the coil are as follows:
Large pink (from harness): Ignition power wire to the coil & distributor module.
Small pink (to distributor): Ignition power wire to the distributor module.
White (from harness): To tach.
White (from distributor): Pulsed signal from distributor module - switches the coil on & off to generate a spark at a plug.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Oct 3, 2001 | 03:40 PM
JMatlock88's Avatar
Car: 1991 Formula
Thank you for the info! Sorry for confusing anyone I guess my pink wire looks orange from fading a little.
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
