Dash Lights Blow Fuse, Where To Start
Old Oct 3, 2001 | 04:57 AM
scull's Avatar
85 Camaro and the dash lights keep blowing the fuse. I had problems with the rear defogger and got it fixed but it doesn`t stay on very long. Need help where to start looking. Scull
Old Oct 3, 2001 | 03:27 PM
mtccl's Avatar
Something is grounding out. Check the defroster circuit again. I believe it is on the accessories fuse as is the dash lights. Do they blow the fuse when you turn on the headlights? I had a chaffed wire behind my radio console that was blowing the dash lights out when it grounded to the chassis. It was a constant power wire not used on the aftermarket stereo. Lots of stuff goes into the accessories fuse. Try to isolate the problem in a systematic approach.
Old Oct 4, 2001 | 01:07 PM
borgx's Avatar
Car: 1987 Pontiac Trans Am GTA
Transmission: WorldClass T5
Axle/Gears: 3.70
My 87 Bird had a wire rubbed bare on the left-most section of the dash just below the A/C vent... There are a grouping of wires that go through a metal support structure which is where it went bare... Lost my dash light fuse everytime I hit a good bump!
James
1987 Pontiac Trans Am GTA - 305 TPI - 700R4
Old Oct 6, 2001 | 10:46 PM
pvknight's Avatar
got a penny in the cig lighter? that shorted mine.
Brian P.
'91 TransAM: 305TPI -=flowed=-
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
