Alt wiring on a 88 IROCZ
Old Sep 16, 2002 | 09:53 AM
Nate1's Avatar
Car: 88 IROC-Z, 71 SS 454 Chevelle
Engine: 305 TPI, 454
Transmission: 5spd, th400
I purchased an 88 IROCZ that the TPI was sitting in the trunk. I have since rebuilt the motor and I am now hooking everything back up. When I came to hooking up the alt it did not have a wire to hook up to the battery post on the back but it did have 3 wires (a gray(I think), white(I think), and a red) in a plug that plugs into it . Does the alt suppose to have a wire from the post on the back of the alt running to the battery or does the red wire in the plug do the job? This is a snag that is keeping me from getting it back on the road. Also does any body have a wiring diagram for this car so that I can look at so I make sure that all the wiring is where it is supposed to be.
TIA
Nathan
Old Sep 16, 2002 | 07:21 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
My firebird and a friends 87 IROC both have a big red wire running to the battery.
Old Sep 16, 2002 | 07:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
85 wire diagrams...
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
86 wire diagrams...
http://92b4crs.tripod.com/86wiring/86wiringindex.html
Both similar (basically exact) to 88.
I was not able to find anything on the 3-wire alternators last time I borrowerd a 91 service manual from the dealership but, the wire colors to the alt. should be (but not exact) red, heavier gauge than the other 2 wire, goes to the starter. Brown, goes to the firewall bulkhead connector then to the volt gauge and tan/white stripe, should be a switched +12v source.
That may be wrong but, that's the way the harness went together in my bud's truck.
There should be a lug on the back of the alt that a 8-10ga wire from the battery terminal goes to.
Old Sep 19, 2002 | 06:59 AM
Nate1's Avatar
I found the wire
Man! I don't think I ever want to try and put something back together that somebody else took apart.
I found the wire to the alt now all I need is to find out where all the vacuum hoses are supposed to hook up.
Anyway, Thanks to everybody that responded.
Deadbird, do you have a schematic that shows where the vacuum hose are to be hooked up?
Thanks,
Nathan
Old Sep 19, 2002 | 07:40 AM
deadbird's Avatar
Engine: TPI 305/ v6
This is the best I have. I copied it from the label under the hood of a camaro at a dealerships back lot.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
podiatra
Aug 31, 2015 09:53 AM
Bryan F
Aug 27, 2015 07:28 AM
IBrockZ
Aug 20, 2015 12:20 PM
chazman
Aug 11, 2015 11:19 PM
