Simple Question- A/C relay
Old Sep 16, 2002 | 05:47 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The Haynes and Chilton manual both show an A/C relay. Where is it?
Old Sep 17, 2002 | 06:54 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I don't need any wiring help, I just need to know its location. I am swapping an LT1 in and it is time to wire up A/C.
Old Sep 18, 2002 | 06:29 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
I am pretty sure they are both wrong. 90 I think gets compressor clutch voltage from the AC request switch in the control head assembly.
Old Sep 18, 2002 | 06:36 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Maybe the A/C relay they are referring to is actually the blower high speed relay - if so, it's located near the blower motor, under the hood, on the pass side, unless you have an '84 - '86 Berlinetta, in which case the blower control relays are under the passenger side dash.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
thunder57
Nov 7, 2015 02:28 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
