Vats ???
Old Oct 1, 2001 | 11:58 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Vats ???
Hi all got a good one here. just did a motor swap in a 1985 z28 it was tpi i went to carb took out the computer also. with every thing hooked up i crank it over and she starts no problem turn it off go back to start it and nothing but i have plenty of juice to everything. wait about 10 mins and same thing she will crank a few times then die
i was just going through some archives here and i noticed certain people had the same problems and they mention the vats does the 85 z28 have the vats and if so how do i take it out completely. thanks
Old Oct 1, 2001 | 12:27 PM
IROCZ89's Avatar
The 85 should not have a vats.
89 IROC 5.0 TBI
89 RS 5.0 TBI, T-Tops, Soon to be a IROC clone.
Old Oct 9, 2001 | 10:22 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Vats did not come out until 86' and was only installed on the corvette. GM did not start putting vats in the camaro till 89'.
Old Oct 10, 2001 | 03:40 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You'll see a "security" light blink on the dash when you start the car if it has VATS. Also the key will have the black plastic resistor with a small metal tab.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
