Brake fuse blowing...
Old Oct 13, 2001 | 11:32 AM
Steve R's Avatar
What would make a brake fuse blow?
Also what i'm thinking is since i'm parting out my iroc, i can take the entire harness out from the iroc and use it in the gta. I dont see any shorts anywhere so i figure i'll jsut avoid the whole problem
Does the harness have some kind of quick-disconnect by the fuse box? Also how is it routed thru the car?
Old Oct 13, 2001 | 02:37 PM
Blade3001's Avatar
I have no idea about the brake fuse but I can tell about my experience with replacing a v6 firebird wiring harness.
It's far from a simple solution. You gotta take out your dash, console, backseats, drivers sail panel (pass side too if your using the harness's speaker wires).
There are two small screws on the engine harness where it goes through the fire wall and then it's clipped in there sorta. The tail light harness is probably different on your GTA. All the options on the cars must match. (i.e. I had to custum wire a hatch poper cause the new harness had a power hatch and I couldn't upgrade to a power hatch cause the welding is different).
On my car it had three pieces; engine, dash and powerwindows/locks.
Don't do it! GTA's and Iroc's are awesome cars, usually optioned well with all kinds of unique exotic devices and you will be doing alot of customizing. If you don't want to find the short then you don't want to change the harness.
In my case I had to, to use a newer MPFI engine. And I wanted power windows and locks (I'll just say that little upgrade was whole lot of fun)
[This message has been edited by Blade3001 (edited October 13, 2001).]
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
