Question about straining the alternator.....
Old Oct 14, 2001 | 07:16 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Ok, I am going to hook up a very mild system in my car with just one 12" sub and some kind of amp but not sure which. And I also wanted to get some aftermarket fog lights for my rs and I started wondering if this would be too much of a strain on my alternator. I have the stock hundred and like four or five amp alternator. If I do this, should I think about getting a higher amp alternator? Also, is it real hard to hook up aftermarket foglights? I was just going to get some stock iroc looking ones(Not the ***** ones)? Anyways, I was just wondering if this would strain it or not. Thanks.
1992 Polo Green RS 3.1L K&N conical and working on the ram air....
"Yeah, it's a V6 SO WHAT!?"
Old Oct 15, 2001 | 03:20 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It shouldn't. I'm not sure what's in my beater 84 camaro but, I doubt it's as high as amp as yours since my car is just a lowly SC. I can run the lights, A/C, wipers, added on driving lights, and very modest 130watt amp. The A/C clutch seems to be the hardest thing on it making the voltage gauge drop to a thin 1/16" off the 13v mark. it goes up and down as the compressor cycles. That's only while all the other stuff is on though otherwise, no 1 single thing is a stress at all.
Do not use the crappy 'wiring kit' that comes w/low cost driving lights. Do yourself & your car a fovor & buy a relay (or relay kit) to hook up your lights. Your wiring & fusebox will thank you. I've added 'stock looking' cheapies to both my cars and using their suggested way of wiring, the wire gets hot & the insulation starts melting over time. While it dosn't bother me in my camaro, my 'bird is getting the stock switch & a relay harness made for its lights.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
